aga hesenov Konu tarihi: 15 Nisan 2014 Paylaş Konu tarihi: 15 Nisan 2014 Radeon R9 270x satiram tezedi 300 azn. Muqayise Product Features R9 270X Sürücü | Kod: 01- PWC - 016- 00660 GPU: Radeon R9 270X Yaddaş ölçüsü - Tipi : 2GB GDDR5 Nüvə Saat Sürəti: 1030MHz (up to 1080MHz with boost Yaddaş Saat Sürəti: 1400MHz ( 5.6Gbps ) Yaddaş İnterfeys: 256Bit DirectX ® Dəstəyi: 11.1 İnterfeys: PCIe 3.0 Xarici Links: DL-DVI-I/SL-DVI-D/HDMI/Dis play Port Graphics Engine Radeon R9 270X Model No AXR9 270X 2GBD5-DH/OC Video Memory 2GB GDDR5 Engine Clock 1030MHz (up to 1080MHz with boost Memory Clock 1400MHz ( 5.6Gbps ) Memory Interface 256Bit DirectX ® Support 11.1 Bus Standard PCIe 3.0 Standard Display Connecors DL-DVI-I/SL-DVI-D/HDMI/Display Port feature Support OpenGL support CrossFireX Technology support ATI Stream Technology support ATI Eyefinity Technology support ATI Hypermemory Technology display Support VGA Output Via Adapter DVI Output DL- DVI- I / SL- DVI- D DisplayPort On Board HDMI on Board TV Output HDTV Output HDCP Support support Maximum Resolution VGA 2048x1536 DVI 2560x1600 DisplayPort 4096x2160 HDMI 4096x2160 Power Specs + Board Dimensions board Dimensions 225mmx130x38mm Minimum System Power requirement ( W) 500W Extention Power Connector Two 6 -Pin PCI Express Power Connectors R 9 270 x 2 gb 256 Bit GDDR 5 , R9270x2gb256BitGddr5 , R 9 270x 2GB 256 Bit GDDR5 , R9 270x 2GB 2 56 Bit GDDR 5 olaraq da bilinər. Radeon-R9-270-Gaming-Performance.jpg AMD-Radeon-R9-280X-Photo.jpg Alıntı Link to comment Share on other sites More sharing options...
Karb10 Mesaj tarihi: 16 Nisan 2014 Paylaş Mesaj tarihi: 16 Nisan 2014 bazar olsun Alıntı Link to comment Share on other sites More sharing options...
Elit-killer Mesaj tarihi: 16 Nisan 2014 Paylaş Mesaj tarihi: 16 Nisan 2014 əladı bazar olsun amma 1az bahadır. Alıntı Link to comment Share on other sites More sharing options...
aga hesenov Mesaj tarihi: 16 Nisan 2014 mövzunu açan Paylaş Mesaj tarihi: 16 Nisan 2014 biraz duwerem qiymetde alan olsa. Alıntı Link to comment Share on other sites More sharing options...
Karb10 Mesaj tarihi: 16 Nisan 2014 Paylaş Mesaj tarihi: 16 Nisan 2014 aga hesenov forumda tel nömrəsi yazmaq olmaz Alıntı Link to comment Share on other sites More sharing options...
aga hesenov Mesaj tarihi: 16 Nisan 2014 mövzunu açan Paylaş Mesaj tarihi: 16 Nisan 2014 sildim bu qaydani bilmirdim. Alıntı Link to comment Share on other sites More sharing options...
Recommended Posts
Sohbete katıl
