Jump to content
Forum Windows-az.com
Flash kart
Recommended Posts
  • 2 hafta sonra...
  • 4 hafta sonra...
  • 3 hafta sonra...
Having a bootable USB is very essential, especially if you are a Netbook user. Using bootable USB to install an operating system (OS) not only makes the installation faster, but also saves a DVD.
Creating or using an USB drive to install Windows operating systems is very easy if you follow the below mentioned steps.
If you are planning to use bootable USB to install Windows 7 or Vista please refer our guides:
Install Windows 7/Vista using bootable USB guide
And also, you can refer install Windows 7 on Acer Aspire One guide
Coming back to bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use “D” as my optical (DVD) drive letter and “H” as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where “H” is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
buyur
Link to comment
Share on other sites
  • 1 ay sonra...
Bir çox zaman biz tanımadığımız komputerlərə flash kartimizi salırıq. sonra goruruk flashkanın vəziyyəti pisdir. elə bir proqram varmi ki, flashkanin içinə yazılsın və komputerə taxdiqda komputerdə harada virus olduğunu gostərsin yəni həmin fayla girməyin təhlukəli olduğunu xəbərdar etsin.
Link to comment
emil73219 sen forumda yeni bolme ac basha salaram nece edensen senin isteyine uygun bir elemek olar.
damid_91 kondensatorlardan biri yansa,onda komp flashi gormez voobshe ona pitaniye galmaz...Deyirsen ishigin oynamagi ? Mentiqle danishaq blok pitaniyenin isleme qaydasini bilsen onda bele demezdin,USB port isledir 3.3 Volt tok teleb edir.neyinsen yanmagi ve ya islememesini postayanni ve peremenni tokla-islemesini nezere almaq lazimdir.Flashi naxalni USB portdan cixadanda bele hallar bash vere biler
mayak18 flash karti Nicat adli istifadeci var idi,ondada bele bir hal olmusdu,kopm gorurudu amma acilmirdi...Duzeltdik prosta forumu yaxshi axtar belke tapdin
Millet islemeyen FLASH KARTLARI ( 4 Gb-dan yuxari ) atasi olsaz saxliyin men goturecem sizden........
Link to comment
Sohbete katıl
Misafir
Bu konuya yanıt ver...
×   Zengin metin olarak yapıştırıldı.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Önceki içeriğiniz geri yüklendi.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • loading...
  • Create New...
